MMC problems with N-gage QD
1 replies · 1,699 views · Started 07 August 2004
Hey. I've a N-gage QD and I bought an MMC card for it. When i loaded it onto my N-gage, it came up with it saying the Card being corrupt. I restarted the machine and formatted it. When i want to take out the card, i do it when it is safe to take out. When i put it back in, it says 'You should never remove the Memory card without pressing the Remov. Mmc", even though i didnt.
Another problem is when i put my MMC card in my PC card reader, nothing comes up. I'm just wondering is the card faulty or can the problem be fixed somehow?
Regards
Zest
Zest wrote:Hey. I've a N-gage QD and I bought an MMC card for it. When i loaded it onto my N-gage, it came up with it saying the Card being corrupt. I restarted the machine and formatted it. When i want to take out the card, i do it when it is safe to take out. When i put it back in, it says 'You should never remove the Memory card without pressing the Remov. Mmc", even though i didnt.
Regards
Zest
http://forum.ngagegaming.com/ubb-data/ultimatebb.php/ubb/get_topic/f/1/t/002363
hope this helps...
