How to Password Protect SMS and Addressbook
10 replies · 9,169 views · Started 08 August 2004
Phew, i didnt know this was possible!! Can i passwd protect SMS on a N3650?
Rubal wrote:Do Anyone Knowwwwwwwwwwwwwwwwwssssssssssss howwwwwwwwwwwwww ?
YOU CAN'T DO THIS..ITS NOT POSSIBLE !!
I've never heard of such trick or of any prog that allows you to achieve the same Rubal. Ek din mein aisa program banaunga, tu tension mat le.
Aaj Hi bana de na ... 😞
Ok .. tujhe pata hai kya FaceWarp kaise chalun 7610 pe .. maine try kiya par nahi chalta hai ..
I might be wrong, and I have not tried it, but you can password protect your MMC card, and since the addresses are on the MMC it should be password protected hereby.
Rubal wrote:Aaj Hi bana de na ... 😞
Havent heard of FaceWarp?? Thoda details de zara.
You can password protect the entire phone, go into security settings/phone and sim, set a lock code, make the autolock period something like 1, and set lock if sim changed to yes. Then when the phone autolocks after one min, you will need to enter the security code to access anything on the phone.
MrJon wrote:You can password protect the entire phone, go into security settings/phone and sim, set a lock code, make the autolock period something like 1, and set lock if sim changed to yes. Then when the phone autolocks after one min, you will need to enter the security code to access anything on the phone.
Cool ..
Thanks,
