Sync (outlook 2002 and 9800) doesn't detect changes on PC
0 replies · 1,965 views · Started 09 August 2004
I'm using the latest sync software (no firmware upgrades on the phone yet) on windows XP, outlook 2002 - sp3.
Most of the sync process works fine, but for some reason when I modify an existing contact or note on the PC it will not be reflected on the p800. It works the other way round.
Creating new records (contacts) on the PC works fine and are transferred to the phone properly. Changes made using the p800 works fine, but the PC changes are ignored gracefully..
Anyone experienced the same? Got a solution?
