MMC cards and the QD
5 replies · 1,971 views · Started 09 August 2004
I searched the boards for this but couldn't find a solution...for the new Pathways to Glory demo, the install instructions state that for the QD, you need an MMC card reader to install the demo on the QD. Is that correct? Is there any way to install it on the MMC via bluetooth or any way without buying extra hardware?
davsug wrote:I searched the boards for this but couldn't find a solution...for the new Pathways to Glory demo, the install instructions state that for the QD, you need an MMC card reader to install the demo on the QD. Is that correct? Is there any way to install it on the MMC via bluetooth or any way without buying extra hardware?
No because when you send it via bluetooth, its going to try to send to the QDs measly 4 mb internal memory.... so you need a card reader to copy and paste it via windows explorer.... its only 15 bucks on ebay, i just bought a 12 in 1 reader from there.. try searching for 12 in 1 reader, 7 in 1 reader or even 4 in 1 reader, or just mmc reader.... they come out pretty cheap, like 5 bucks plus 5 bucks shipping. hope this helps.
It seems odd that one can use the Nokia N-Gage QD PC Suite to transfer files directly to the MMC via Bluetooth, but they say that one requires a cardreader to install it.
I'm going to fire up my Bluetooth adapter on my PC here and get to the bottom of this...
[UPDATE]:
Using the QD PC Suite, one can indeed install the game directly to the MMC. You'll need 15 MB of free space, but it works fine (other than taking about 15 minutes to copy over - Bluetooth isn't exactly fast).
Anyways, the game starts up and appears to run fine. I'd be playing it now, but apparently I'm supposed to be "working" since I'm at the office...
Wirelessly posted (Nokia N-Gage: NokiaN-GageQD/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
Pathways to Gory demo? Are you sure it's not pirated; where did you get it from?
Yep, I'm pretty sure that it's not pirated! :icon14: Looks like a neat game, but I haven't really had much time to play it yet... stupid work, it's like they're not paying me to play games, or something!
