Hello guys,
I ve got 2 questions.
First, Is it possible to change the front "cover" of the Nokia 6600,
and secondly, when i try to connect my Nokia 6600 to my PC through Infrared
the phone stops responding and after a few seconds it goes back to the White Screen with NOKIA at the bottom, and then in the Stand by mode.
Any suggestions greatly appreciated
Thank you,
Stavros
Originally Posted by smsmasters
It's easy, just open the battery cover, insert a small screwdriver into the two holes to release the pressure, then what I do is use a guitar pick to slide around the cover from top to bottom. Comes off in <1min
To change the cover at a Nokia service center is some 25-30 euros... price may vary....
Any suggestions about the problem with Infrared?
Check in the bios of your PC how it is set. Try the other alternatives. (Mine is set at fastIR.)
Try without the MMC in the phone...
Otherwise it sounds like a firmware-problem... Check with your Nokia service center if they get i to hang too... They may upgrade it for free if you're in warranty time.
/Roger
hellooo
well as ya know for the cover ... it's a piece of cake
& for the other problem ... once it happened with me ... my screen went totally blanck !! but i tried again & every thin was cool ... just try again ...
thanks for the post on how to change the cover....finally i got it sorted!!
now, any suggestions on how to keep fingermarks off a chrome silver cover? lol
