NMAKE : fatal error U1073
1 replies · 2,187 views · Started 10 August 2004
hello!!
this the error i got when i try to create the exe for a real phone!!
above this the result and you can check at the end there is an error
NMAKE : fatal error U1073: don't know how to make
I really don't know how to solve it !!
thanks for your help
JP
WARNING: Should install MSVC6 Service Pack 3
nmake -nologo -f "\Symbian\6.1\Series60\EPOC32\BUILD\SYMBIAN\6.1\SERIES60\SERI
ES60EX\TEST1\GROUP\WINS.make" LIBRARY VERBOSE=-s
nmake -nologo -s -f "\Symbian\6.1\Series60\EPOC32\BUILD\SYMBIAN\6.1\SER
IES60\SERIES60EX\TEST1\GROUP\TEST1\WINS\TEST1.WINS" LIBRARY
ES60EX\TEST1\GROUP\WINS.make" RESOURCE CFG=UDEB VERBOSE=-s
IES60\SERIES60EX\TEST1\GROUP\TEST1\WINS\TEST1.WINS" RESOURCEUDEB
Reading resource file...
Adding icons
Reading icons
Adding captions
Adding capability
Adding data types
Adding view data
Adding file ownership info
Saving
ES60EX\TEST1\GROUP\WINS.make" TARGET CFG=UDEB VERBOSE=-s
IES60\SERIES60EX\TEST1\GROUP\TEST1\WINS\TEST1.WINS" UDEB
NMAKE : fatal error U1073: don't know how to make '"\SYMBIAN\6.1\SERIES60\EPOC32
\INCLUDE\EIKCLB.H\"'
Stop.
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio\VC98\Bin\n
make.exe"' : return code '0x2'
Stop.
ES60EX\TEST1\GROUP\WINS.make" FINAL CFG=UDEB VERBOSE=-s
Did u manage to fix the bug or not ... let me know .
i am also facing the same problem...
is it something related to Version of Symbian Serier SDK 60.
