smartmovie & bluetooth
3 replies · 12,204 views · Started 10 August 2004
anybody help, have been playing with smartmovie... tried various bitrate combos, codecs etc. videos are converted with the smartmovie convertor and loaded to my phone useing bluetooth, video and audio are great while still connected to the pc but when the bluetooth connection is terminated the audio is not good, stutters and intermitant video is ok.... realplayer replays ok as 3gp but i like the full screen of smartmovie,,, any help appreciated
angus wrote:anybody help, have been playing with smartmovie... tried various bitrate combos, codecs etc. videos are converted with the smartmovie convertor and loaded to my phone useing bluetooth, video and audio are great while still connected to the pc but when the bluetooth connection is terminated the audio is not good, stutters and intermitant video is ok.... realplayer replays ok as 3gp but i like the full screen of smartmovie,,, any help appreciated
try this settings, cuz it works on my Nokia 6600 well
Video
=portrait
=reduced frame
=codec: xvid encoder
=bitrate: 128 kbps
Audio
=enable
=force mono
=frequency: 16000 Hz
=bitrate: 24kbps
=codec: lame mp3 codec (i think it's the default codec)
=volume boost: 200%
i hope it'll work well on your phone too,. good luck😊
if you still encounter audio problems while playing your video clips, try changing the "audio preroll time" on the option menu,. mine is usually set between 0.30sec to 0.40sec
I can't use "Xvid Encoder" in Smartmovie in Nokia 6600. It displays "no codec for video format DIV3". I have alredy installed Xvid codec for my mobile. Can you help me? Thanks
i've got smart movie.... i need to know which coverter to d/l an' how do i get it....that is from which website:????? :icon4:
