mmc problems
3 replies · 1,599 views · Started 10 August 2004
Hi there,
New to the n gage and new to the forum.
Just been and bought an mmc and each time I put it in my n gage I get the card corrupted message. Ive formatted it and still it appears. Ive put it in my pc card reader and that will not read it until I format it, then it appears ok. But as soon as I put it back in my ngage it says its corrupt again. So to simplify it, I can get it to work on my pc but no matter what I try on my ngage, nothing seems to work.
the card is brand new.
Thanks for any advice.
Dazza
dazza wrote:Hi there,
Dazza
Sounds like a faulty MMC.
what brand of MMC are you using?
try checking the "Tested MMC Card" topic if your MMC is compatible with the n-gage.
somebody pls help me! how to transfer themes using Card reader. to MMC what folder am i goin to paste it.. thanks :?
