Task Manager
1 replies · 2,371 views · Started 27 November 2001
I am trying to delete Task Manager but there is a file called TaskManager.rsc which I cannot get rid of . When I try to delete it says that it is in use and I canot find any way of closing it down .
Can anyone help!
Start Taskmanager itself, then press Options - Reset Machine and finally press Disable Taskman.
This will reset the device and will not start Task Manager. So you can now unistall it without problems!
Hope this helps!
