hey all
9 replies · 2,063 views · Started 28 September 2002
hi all.. sorry for that diconnection, i'm ready to help now :P
i wanna be sure about something.. in the Install Log (install/remove programs) i have [Nokia 9210i data] installed on 02/02/2002/ 1:14 pm,
does that mean?? the mobile has been used before or what??
I have to agree with Dazler.
check out your Z: rom drive and you will see the files are maybe of the same date you stated above... so this means it's Nokia's installation.
[quote="TooSpecial"]
Thanks[/quote]
That's default date when you format 9210i.. So if you format your 9210i now and don't set date and time, you have date 02/02/2002
The z drive only contains a System dir. You have to set the option in filemanager "show system dir". (something like that, don't know exactly how it's called but it's in the menu)
[quote="Dazler"]The z drive only contains a System dir. You have to set the option in filemanager "show system dir". (something like that, don't know exactly how it's called but it's in the menu)[/quote]Not only an system directory but olso "Show ROM" Yes 😉
Then only you can see the Z drive 😉
