A925 desktop change
5 replies · 3,971 views · Started 12 August 2004
Does anyone know how to change the homepage of an A925. I have the phone on 3 and there are some annoying banner ads on the homeapge. (which i wouldlove to know to get rid of)
I tried Tracker and i can only seem to use it as an application but i want my phone to use it as its homepage if possible.
from launcher go to
tools/control panel/shortcut key
Then just choose what app you whant to set it to ex. tracker.
Once that has been done everytime you press the shortcut key it will take your phone to the desired app.
I don't think it's possible to replace the quickapp buttons on this phone.
I know it could be done on the SE p800/900
But i haven't managed to do it on this one.
Changing the "shortcut key" isn't the solution though.
Something that annoys me is that i can't set the default homepage in the browser.
Not sure if i understan what you mean. But if you mean to change the meny bar on the top of the screen (The icon beside Phone, browser etc) there is a cheap ansd easy way. Go to "www.my-symbian.com och download the freeware "AppickerConfig in there UIQ section. THen you can change the menys as you like for free.
Best regards
Peder Nakazul Tjernberg
Are you on about the "3" links on the homepage?.
There is a piece of software called "A920 menu" than can change the text colour and the url links, i don't think you can change the icons though.
