smartmovie 2.43
8 replies · 3,009 views · Started 12 August 2004
this version of smartmovie DOES work with the sendo X.
i'm currently testing with the different settings to get the best quality with the fastest screenplay.
any of you have some tips ? 😊
SPEEDMAN wrote:this version of smartmovie DOES work with the sendo X.
Hi SpeedMan, last SmartMovie version runs on Sendo X (but oldies too), but there is frame skipping among video and audio, I just test on landscape and portrait mode, XviD codec (300 bitrate that's low, 1 pass CBR - medium quality), and audio to minumum and skipping too... 😞
matthia, the previous version wouldn't work with sendo
if you take 64kps video and 22 khz at 40kps sound it should go without any skipping.
BUT don't forget to choose reduce frames or you WILL have skipping! :icon13:
SPEEDMAN wrote:matthia, the previous version wouldn't work with sendo
SpeedMan, with "reduce frames" options, with XviD codec to 64 of bitrate, medium quality, 1 pass CBR, with 22hz at 40kps skipping too!
And at 64kps it's all pixelled!
It need minimum at 256kps of bitrate if no it's better PvPlayer!
Matthia wrote:SpeedMan, with "reduce frames" options, with XviD codec to 64 of bitrate, medium quality, 1 pass CBR, with 22hz at 40kps skipping too!
Matthia, then it is up to smartmovie to fix it.
SPEEDMAN wrote:Matthia, then it is up to smartmovie to fix it.
Then, SmartMovie doesn't work well on Sendo X too...
However, oldies versions of SmartMovie works on Sendo X but only without audio and framerate is good, with movie with audio then player stops...
Matthia wrote:Then, SmartMovie doesn't work well on Sendo X too...
i don't understand your last sentence, i'm sry :?
Have you got some news ?
Thank you.
yes i've got news:
movies have lag in sound AND screenplay in every configuration.
it's just not compatible enough yet. :icon13: :icon13: 😡
