Does anyone know how I can view MPeg files on the 7610? or avi etc... basically video clips from my PC?
thanks
justin
thanks
justin
Hi!..
Yep... the best app for that it's ... SMARTMOVIE ...
There you can read all about it ... I got it and it's really amazing app...
the best image quality ever seen on any S60 phone... i convert videos to AVI (DivX or XVid) with up to 256 kbits/seg of quality and 32 kbits 32 khz Audio... and no problem playing.. really good app...
cya!
I though so I d/l that but didnt get round to using it. Ive been using today but its says I need the CRAM codec? Ive installed the codec that come with the smart movie but its hasnt worked. Any ideas?
hi..
i don't know that problem... i use XP Pro.. and it don't said me that codec request on install...
sorry that i can't help you...
cya!
can u tell me which service pack supports xp and i want to use my 7610 on xp and can u give me any new themes downloadable themes site other than symbian world, i mean free downloadable themes, i will b thankful to u
