WindowsXP compatible with PC Suite??
7 replies · 2,535 views · Started 29 September 2002
i don't know wheater it compatible or not,
can anyone tell me about connect my phone to PC using infared port,,thanks...
No problem for me too..just install the nokia pc suite software and also insttall the infrared software ( i have irwave irda) and it works fine with windows xp home.
Sometimes when you install programs direct by double click it might not work after a few installs.
ActiveSync (for PocketPCs) went a bit funny at first but it sorted itself out without any intervention from me. Other than that, it works fine with XP transfering over IR for me!
😃 PC Suite and my MSI Bluetooth Device works fine in my Win XP Pro.
No problem faced so far except when boot up i will see a popup windows saying the bluetooth server is busy and click retry or GOTO. Either I leave it or click retry after all services are up and running. Then it works. Not a big or small problem for me.
8)
It seems to me that it is different for almost everybody! I have XP Pro, MSI and I have no error at the bootup! I have other errors but everything works fine, except the backup but I gor around that!
😃 Me too ... I have Thinkpad T30, and Nokia Suite just working fine except somitime you have to restart the suite to refresh the pics directory for image transfer 😉
i don't get any errors, but i do have to disable my LAN connetion to allow my bluetooth dongle to connect. :/
