unknown problem
14 replies · 2,877 views · Started 15 August 2004
Hi all, I have use my P900 as normal but how come some time after a full charge, without using the phone but after a while say two hours the battery show "low battery". it happened not often but few time already. Please help.
Hi all, have another problem again, this time while i have to delete some files from my memory card, it say access denied. What is the problem regarding about. please help
csn0318 wrote:Hi all, have another problem again, this time while i have to delete some files from my memory card, it say access denied. What is the problem regarding about. please help
Maybe you accidentely enabled the file-safe switch on the back of your MS Duo card...
Till now still cannot solve this problem. i have borrow my friend P900, it do have same problem as mine.
Ohh..... i still talking abt that problem. Please teach me how to off the file-safe as my MS Duo doesn't have any on/off switch.
I have three, one MagicGate and two ordinary ones, and they all have lock switches on the reverse side.
I do have ine original and one magicgate Lexar media but both don't have the on/off switch. anyway to solve this problem....
What files are you trying to delete? Is it possible the files could be in use? Is it any file on the memory stick or is it just some of the files?
Its a software which I install inside my MS DUO but then I try to use different phone to uninstall it, it say access denied.
Do you have a memory card reader (if not, I seriously recommend one anyway)? If so, you could use that to delete the file via your PC
They are only about �5 and are many, many times faster than the Synch station for transfering files. To be honest, having used a card reader, I don't use the synch station for transfering files any more. Just for synch and backup.
Plus, if you get on of the multi-format ones, they'll read the card from a digital camera, MP3 player etc. as well.
