app closed - main
12 replies · 8,110 views · Started 15 August 2004
when i started up my phone, it gave me a warning - app. closed Main- but i cud access every app. in my phone. does app. closed main mean any harm to my applications??????
rohit
rohitkhannak45 wrote:when i started up my phone, it gave me a warning - app. closed Main- but i cud access every app. in my phone. does app. closed main mean any harm to my applications??????
rohit
we have the same problem
cheers!!
I think this error is related to Psiloc applications. Try uninstalling those you may have and see if it makes a difference.
Airwalker wrote:I think this error is related to Psiloc applications. Try uninstalling those you may have and see if it makes a difference.
Usually it wont even uninstall as my friend had the same problem. With that you would have to delete manually psiloc stuffs, i mean all traces, but what the heck if you have a back up of your phone and all the stuffs you need, id recommend a format.
Most Psiloc files will uninstall, its just a matter of leaving it for a minute, even if it looks like the phone has locked up completely. But yes, if that doesn't work I'd just format. Keeps everything running smoothly if nothing else.
thanks for the suggestions (i am actually rohitkhannak45 [the one who started this thread]) but i dont have any psiloc apps - and another thing. EProfilesPRO only allows you to select the alarm from *.mid and *wav files. i need louder ringtones - like the intro tune on the phone. Any other program which can play ALL tunes [when i say ALL tunes, i mean like how the list of ringing tones in standard profiles app.]???
rohit
rohitkhannak wrote:thanks for the suggestions (i am actually rohitkhannak45 [the one who started this thread]) but i dont have any psiloc apps - and another thing. EProfilesPRO only allows you to select the alarm from *.mid and *wav files. i need louder ringtones - like the intro tune on the phone. Any other program which can play ALL tunes [when i say ALL tunes, i mean like how the list of ringing tones in standard profiles app.]???
rohit
Eprofiles is a Psiloc application. If you mean play mp3s its not possible. Place your *.mids and wavs in the digital folder in sounds maybe that'll work or some directory where eprofiles points its sounds.
rohit
Open one of ur message and keep pushing the joystick to right will do. hope it help
Whay was that? Could u pls explain it to us?
Please try to remove all Psiloc applications from your phone, including all 'Common...' components (if any) - this can be done from Application Manager. After that please restart your phone and reinstall the program from Psiloc's web site (www.psiloc.com) once again. Please install application in phone memory.
I have Classic N-Gage. Format the phone (*#7370#) so many times. Doesn't have any kind of psiloc products installed on my mmc. But I'm still receive that errors. So, what's the solutions?
rulirahm wrote:I have Classic N-Gage. Format the phone (*#7370#) so many times. Doesn't have any kind of psiloc products installed on my mmc. But I'm still receive that errors. So, what's the solutions?
Did you try to install it in the phone memory, not on the MMC?
