6620 Questions
2 replies · 3,814 views · Started 15 August 2004
Nokia's user manual is really horrible. It answers NO questions one might have about the phone.
Here are my 2 questions:
1) How do I manually enter (and make it work) an rttl ringtone? It seems like it shouldn't be that hard to do
2) How do I delete one of those stupid little apps they put on that you get to try twice before they expire?
Also, not really a solutions oriented question, but has anyone else had problems with it having a VERY short battery life? I've only had it 2 or 3 days, and after less than 1 day (of very little use), I got a "battery low" warning!
Thanks.
those lil apps can be uninstalled in the MANAGER (app. manager). click on it, you'll find all applications (games, mp3players, etc) in there, remove them or update them its all in there.
did it help?
Wirelessly posted (NokiaN-Gage/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
Battery life willl improve (probably) after a couple of charges. You should get 3 or 4 days. Ring tones can not be entered directly. Poly phonic tones are the norm on these phones. Remove apps using manager in the tools folder.
