Hello -
How do I use Nokia 7610 as a Webcam Device ?
Can anyone help.
Thanks,
Hello -
Can anyone help.
Thanks,
Try 'Remote S60' you can use it over bluetooth connection.
Springheeledjac wrote:Try 'Remote S60' you can use it over bluetooth connection.
Thanks,
this feature would be relly good as it would save us alot of money, is there anyway to do this wen it is connected by the data cable!!??
Remote S60 works with cable, IR, bluetooth etc. Marvellous little program. If only it didn't cost 30 squid.
is this program avaliable to have a free trail?? :top:
Try pasting 2 aa's at the end of your nickname 😉
What about trying the shop for a change: Remote S60 Pro,Remote S60 Home,Remote S60 lite.All of them have trial versions.
Nyxmorph wrote:Remote S60 works with cable, IR, bluetooth etc. Marvellous little program. If only it didn't cost 30 squid.
Hi.can anyone explain how do i use this remote s60 with my DKU2 cable? I am not able to connect to my pc. I am currently using the suite 6.4 and remote 2.12
is pc suite really required??? i tried the rs60pro it works but its a demo version for now... i have the rs60 1.10 version.. does it work on 7610??? becoz my uncle bought it last time.. not the latest version though... do ytou think it would work on 7610? the rs 1.10?
i can't seem to let my web cam work... what settings do i have to input in there??? im using yahoo messenger... and i want my 7610 to be used as meb cam in ym...
yes, i cant seem to get Remote S60 connected to my phone!!?? would someone pls tell me a step by step way to mae Remote S60 work!!??
i just need to know can the DKU2 cable works with remote S60. i have emailed the support,but there is no reply.
