Hi all
I was wondering wsa there any way to move a program from the Apps directory to the Games directory?
Many thanks
Hi all
Many thanks
Um... where's your App's directory? If it's one of the folders that you see when you press the Menu button, then just go to the app and then select Options and then select Move to folder, and then select the games folder.
I think...
its the one under tools than apps.
I have that racing game saved there but i want to put it into the games directory
Sorry, don't think that's possible. The apps in that folder are J2Me (java) apps and for security reasons, I believe they're quarantined there.
When I get round to it, I plan on trying to write a program to add a link to them in the favourites folder. It should be possible 😉
[quote="merlin"]
When I get round to it, I plan on trying to write a program to add a link to them in the favourites folder. It should be possible 😉[/quote]
This would be great! Please write this program! 😊
When I get time to install the SDK, I'll take a look at doing so. If it's not too difficult to do, I'll post it up on the boards when it's done. Don't expect it in a few days though....more like a few weeks. I've not even looked at the SDK yet, so I don't know what I'm letting myself in for. Should be interesting though 😉
for me i just moved the app in the tools to the games folder
it helps a little bit 😃 😃
