Is it possible to store the incoming sms directly on MMC insted of on the phone memory.
I usually did it on my 3650, but with the new N-Gage seems impossible....
...any tip?
Thanks a lot,
Niubi
...any tip?
Thanks a lot,
Niubi
Niubi wrote:Is it possible to store the incoming sms directly on MMC insted of on the phone memory.
I usually did it on my 3650, but with the new N-Gage seems impossible.......any tip?
Thanks a lot,
Niubi
MsvDriveE
I haven't seen or tried this application but i wouldn't recomend it to anyone.Nokia probably had a good reason for leaving the incoming sms folder on phone memory.
Bear in mind its probably not a good idea. If you get an SMS wihen you have a read only card in (any of the games cards) storage will have to default back to the phone...
Yes it is possible to store sms directly on MMC. There is a patch availble to do that. I did it once. If u run the patch all the new messeges will b store on MMC. You will not be able to link it to the internal memory messeges though they are there in the card (I have reverted back somehow 😉 as i wanted my msg on internal memory)
You can search. Search for "
Right now i dont remember the exact group name.
is having one such .sis file.
hey is it safe to install that patch?
tell me how u reverted back to yer internal memory please? 🙄
