Hey veterans, you know of some good sites to find nice icons to replace the original ones? (such as contacts, bluetooth etc...)
I found some themes that have 3d icons, but I can't find many out there.
You'll find some in a sticky on the forum at www.mobile9.com
They're mostly the 'plain' ones you already have in Theme Studio in different colours, but you will find some originals there as well.
To be honest, I don't bother with icon sets. You have to change them one at a time and unless your processor is up to it, it will take ages. Instead, once the theme is on my phone I select edit and apply icons from another theme.
Thats definately the best and easiest way 😊
I always use the icons from the ketix theme as they are the best i have seen so far. 😊
elton wrote:Thats definately the best and easiest way 😊I always use the icons from the ketix theme as they are the best i have seen so far. 😊
ketix? may i see... 😃
ripley wrote:ketix? may i see... 😃
Ketix theme with icons. :icon14:
yes very nice... very colorful.... 😊
Sandinista wrote:You'll find some in a sticky on the forum at www.mobile9.com
I am trying to figure that one out...how do you edit icon sets?? I dont see anywhere to edit them...
On the 6600,
Go to themes menu,click on the theme you are using and an edit option will come up,then pick the icons from another theme installed.
The 7610 has not got this option and as you cant find it on 6620 it may not have too 😡
at www.mobile9.com in the sticky post of icons you have a zip with 3 bmps files each with more than 120 icons that I gathered from the net than you just have to use Paint to get them in 44*44 or 44*29 😊
Hope you like it!
elton wrote:Ketix theme with icons. :icon14:
cool i like it thanks :icon14:
I didnt make it,
Welldone to whoever did :tongue:
Kinda stinks that the 6620 dosnt have the option to pull icons from another theme...Grrrr
Nor 7610 !
elton wrote:Nor 7610 !
