my 7610 has a problem the time of the phone(which is correct) is different from the time recorded by the call register or the Log(which is 30-35 mins behind the current time).. for example if the curr time is 1730 then phone clock shows the current time as 1730 but if i recieve a call at 1730 the time recorded by the Log is 1700...
please help it is very irritating and othing seems to be working... i have tried switchng on auto time update and also switching it off
time clash in 7610
saurabhbatra wrote:my 7610 has a problem the time of the phone(which is correct) is different from the time recorded by the call register or the Log(which is 30-35 mins behind the current time).. for example if the curr time is 1730 then phone clock shows the current time as 1730 but if i recieve a call at 1730 the time recorded by the Log is 1700...
I got the same problem. tried everything (Auto update, GMT, etc.) but couldn't find where to update the log time. Guys, please help! this really is irritating! Maybe this has something to do with the where the phone is purchased....I am in india now and bought the phone here itself....maybe there's something like another internal clock which is set to maybe singapore time or something....
help would be very much appreciated.
Thanks,
Raaj.
There Would be normal Time If GMT offset is +0000
Just Go in Extra Folder and then Clock
Option -->Settings
See That u have the following settings:-
Auto Up Date "Off"
GMT offset "+0000"
Day Light saving "Off"
It Will say that u want to update the time
Just press No and Your problem will be alright
Do You have any 3rd party software like Handy World Clock or Psiloc or World Mate.
Vicky wrote:There Would be normal Time If GMT offset is +0000Just Go in Extra Folder and then Clock
Option -->Settings
Auto Up Date "Off"
GMT offset "+0000"
Thanks a lot, vicky! It worked! My GMT was set at +05.30 and when I changed it to +00.00 and updated the time, everything works fine.
No, I don't have any third party world-time software. Anyway, thanks again.
Cool.
Raaj.
Option -->Settings
Auto Up Date "Off"
GMT offset "+0000"
hey..........i do not have the GMT offset option in the settings...pls help..........also i had installed psiloc world clock evalution edition.........which i have removed........
