Im looking at buying a mmc reader and i was wondering if it mattered what brand i brought? would any MMC reader i buy be able to send data to and from my 6600 to my pc??
MMC Readers
aps wrote:Im looking at buying a mmc reader and i was wondering if it mattered what brand i brought? would any MMC reader i buy be able to send data to and from my 6600 to my pc??
No. Find the one that would be able to read your MMCs capacity, there are some that only reads certain Cards at certain capacities. Im talking about higher capacities here like 128 or 256 or perhaps 1 gig if you have one... I dont know if the new ones doesnt have limits but that was one thing I considered when I bought mine. Most card readers also have more card slots which means it can read other Cards as well consider this as well if you have other digital devices with External Cards so u may be able to maximise the use of the card reader you'll be buying.
I have a Lexar 2.0 usb multi-slot memroy card reader and it works great. I have a TEC 512mb mmc. If you can find that brand then I highly recomend it. Good Luck!
