hiiiiiiiiii i am santosh from india .. want to help you all out there who want to have their memory card unlockedd....
you need a infra red cable or any data cable for nokia 6600 .. and have a
software called fexplorer ... in the *.sis *.jad or *.jar file format in your pc
:icon14: system... upload this software to your mobile with the locked memory ....
goto the fexplorer from your mobile after installation and then try getting a file by
search option in that find mmc store send this to your pc system and open this
with notepad in your pc system you will get that password ....that allll
happy time sss alwayssss
byeeeeeee
your faithfull
sksy1234 wrote:hiiiiiiiiii i am santosh from india .. want to help you all out there who want to have their memory card unlockedd....you need a infra red cable or any data cable for nokia 6600 .. and have a
byeeeeeee
your faithfull
6600 has a file manager aint it? why not use that instead. Copy the file, dump it somewhere, rename it to *.txt then open it.... Is that right?
The built-in File Manager will not show all directories & files on the phone.
N/A wrote:The built-in File Manager will not show all directories & files on the phone.
O Ok, but I guess its possible to do it just from the phone without transfering it to the pc. 🙄
Hi. I have a difficult problem, maybe u can solve it. What u said it`ll be easy if I haven`t formatted my phone`s c:\ drive with *#7780# code. All that after I`ve deleted my "corrupted" backup from the PC. I`ve tried to use data recovery soft, to restore the deleted files, but it doesn`t work. Should I mention that all that happened in 13th of August, and it was friday. 😊)
Do u have any idea about how can I bring my MMC back to life?
Thanks in advance!
If the original mmcstore file is gone, I suppose there's nothing you can do, except pay some data recovery company like IBAS or others. It will, however, be costly (they will charge you for the work without any guarantees that anything can actually be recovered), so you'd have to have some pretty important info on the card.
Hi
All I had an ngage with 128 mmc I sold it now own 3650 but the mmc is asking passowrd i never put a passowrd .... help me
eor sugession was good i tried also the password came on the pc as well,but the password was not acessing.its saying incorect password nd try again.plz sugesst what 2 do next i am in deep bad trouble. i am uploading da software i had worked with. plz help.
Nope, that's not good. www.gosymbian.com and get the latest FExplorer (1.15 released or 1.16 beta) The one that's posted is an ancient one 😉
I'm unable to find the file mmc store/ mmcstore on my phone.
Can anyone help?
i have forget mmc password
MMCSTORE.txt open but password shwoing this word
pcb�� w 0 p
� wht is this
and i tyring this password but not working
plz help me
