I recently upgraded xp to sp2. It broke my widcomm bluetooth installation and I can't get it working again (reinstall ad nauseam). Previously it was extremely flakey but I could get it to work with PC Suite eventually.
Using the sp2 bluetooth drivers I can see my phone and send files to it. I have configured it to set up a serial port. With the widcomm software the flakiness was in connecting my phone and pc reliably - the XP SP2 bt software does this very reliably - the problem is though that I cannot get PC Suite working.
I an send files individually to my phne but this is a real pain, and what's more I cannot seem to find the forwarded files (which are recieved as messsages using fe exploere - as a reuslt they clog up the phone memory - I can't move them to the MMC card which has much more space.
I configure a serial connection to use com ports 4 and 5 but if I try to select them in mrouter it claims they are already open and will not use them. If I right click mrouter and ask it to connect to bluetooth devices it complains about a socket error.
Has anyone got PC Suite to work with the SP2 bt software, or if not can you tell me how I can export recieved files to the memory card?
Cheers,
Ed
Not sure if this will help, but check out this post
Link
Hope no one objects to me posting links to other forums.
I had a problem when I first tried PC Suite with the SP2 Bluetooth. It started working when I disabled the "show an alert when a device attempts to connect" (something like that anyway, i don't have a machine with it on at the moment) on the advanced propertied page.
The biggest issue I have is that they removed the disconnect button.
Once connected to mrouter the only way to disconnect is to disable bluetooth on the phone.
I still get the unable to open com port message when I try to check it in mrouter.
COuld someone who has got it workign please go over step by step and maybe they are doign something different. 😊
I know the feature list is shorter but it loses nothing I used and it connects much more stably than the widcomm software - the only problem is I can't get it to talk to PC Suite.
hi kurgan, i have winxpprosp2 installed on my box and everything works like a charm with nokia pc suite. im using linksys bluetooth adapter. kurgan, let me know what step by step you need.
i got a msi + sp2 final, and it give me a hard time to connect to phone and pc, sending file to computer with no problem, but to phone is very complicated, OBEX is not installed, how can i install that??? i'm now connecting mga 7610 thru usb cable, but 3660 and 7650 cant connect to sync with the datasuite, how i can connect it???
I menaged to make widcomm drivers to work with my no-name BT dongle, but wasn't satisfied as each time i wanted to make the connection IE hang, and desktop was instantly restarted (still, the connection was made). I tried IBM drivers, no desktop restart here, but after starting the conenction through the BT icon it freezes, and i could reconnect only through My BT Places or so. Still, was able to make PCSuite work. Now i tried using the native SP2 drivers, and i have an issue 😊 how to initialize the connection :/ the outgoing and incoming ports are listed, configured to use COM 6 & 7 (as before), but I can't find a "connect using serial port" option anyware :/
