Can someone tells me if this appl. works on my Nokia 6230. I downloaded it from symbianware.com but don't know what the do.
Any help would be appriciated!
Full screen picture & Nokia 6230
I will not work. The 6230 is a Series 40 phone and uses a Nokia proprietary operating system. It can run Java applications (so called MIDP 1.0 midlets) that are designed for the Nokia Series 40 phones.
The 6230 will not run Symbian/Series 60 applications like the app you mention. Series 60 phones are listed, e.g., here: http://www.series60.com/products
N/A wrote:I will not work. The 6230 is a Series 40 phone and uses a Nokia proprietary operating system. It can run Java applications (so called MIDP 1.0 midlets) that are designed for the Nokia Series 40 phones.The 6230 will not run Symbian/Series 60 applications like the app you mention. Series 60 phones are listed, e.g., here: http://www.series60.com/products
is there a possibility to run it on my phone
As I thought I already said: No. (The "I will not work" is missing a 't' & should read "It will not work".)
