Uploading mp3 problems
2 replies · 1,668 views · Started 17 August 2004
Hi all
I'm trying to upload some mp3s to my phone using the Nokia PC Suite. However, it insists i only have 6mb left on the phone which i believe is referring to the sim memory and not the memory card. It wont let me upload anything.
How do i switch from it using the phone memory to ht ememory card - of which i have over 50mb still left to use?
Thank you
Coogee wrote:Hi all
Thank you
Just use the phone browser (which appears under My computer) when ya have ya phone connected and PC Suite (6.2 Im using) installed. Then you can browse to the Memory card and paste where ya like. Takes a while to copy over big files though ... Zzzzzz ...
Hi! Run PC Suite and go to transfer files. When the explorer opens, browse to your phone's MMC Card which is E: or whatever you named it. Don't transfer MP3s to C:, that's your phone memory.
I wouldn't recommend you transfer MP3s to phone cause they just take too much space. I suggest you use the PC Suite to decode songs to .aac files which take less space but lower quality than MP3.
Another suggestion is to get bigger capacity RS MMC, but they're a bit expensive. (Now you can get them up to 512 MB) Try www.expansys.com.
You better off getting a MP3 Player, cause really... 7610 won't do a good job playing good music.
Rudyn 😉
