Delete all calendar entries?
10 replies · 4,029 views · Started 29 September 2002
You can use the purge command to delete before a certain date, I don't think there's an option from a certain date to a certain date though. It's all before a certain date only.
Sorry, what "purge command" do you mean, in which menue? I can only delete one single entry in the calendar.
Second possibility I found is deleting the file "Calendar" at System/Data with SeleQ ... but I'm not sure if this is good. 😊
if you choose the delete command in the calendar there is a seletion press right of the joystick and there are delete before and delete all entries
[quote="Pichu"]if you choose the delete command in the calendar there is a seletion press right of the joystick and there are delete before and delete all entries[/quote]
Sorry, dont find this selection. There is no small arrow beside "delete". If I choose delete on an entry there is only a confirmation "delete entry?" and thats it. Perhaps this selection is only for recurring entries? Or I have another OS version? Or I am blind ... ? 😊
what what i don;t get it
first u set the calendar view to monthly view --- then in the calendar --- press option --- then choose delete and there are 2 options you can choose
is this what you want or i get it wrong sorry for not helping
ahhh - in monthly view I can see what you mean Pichu. 😮ops: Please accept my apologies. 😮ops: So next question does "delete all" delete just that month or is it really "all"
