I use Smartmovie to convert avi files to transfer to Nokia 6600. The configuration is "Xvid Encoder". After I transfer this file to my mobile, the Smartmovie in my mobile can't play this file. It shows "no codec for DIV3". Who can help me? Where can I get DIV3 codec for Nokia 6600? Thanks
DIV3 Codec for Smartmovie. Help!!!
you need to install the xvid codec for your mobile ON your mobile. you can find it on the smartmovie site :icon14:
I am also having the same problem... I tried installing various types of codecs on my phone but it doesn't work... Maybe im not doing it right... or maybe it's just the wrong type of codec... What type should i use and where should i find it? Does anyone have advice on codecs for my 6600's smart movie?
