3650 prob with pc suit
7 replies · 2,970 views · Started 17 August 2004
Everything (infrared adapter, phone infrared) is working but when i go into pc suite for nokia i get message.
"this is the first time you have used pc suite, please attach your 3650 and press ok"
Well i do this and press ok but nothing happens lol.
Any help here folks.
I have just installed latest "m-router" and this is working ok but still not getting into pc suite.
Thanks.
i also get the same error... whats hould i do to go ahead and proceed ...... is there any other software .....plz email it to me or reply and information to [email][email protected][/email] thanx friends
I bought an IR-Adapter and installed the drivers. The connection does work but after a few time it breaks down, even if I'm transferring some data this time. Anybody knows what to do?
IRDA or Infared is poor quality and unstable. Try bluetooth dongle although there can be quite a learning curve depending on the dongle you choose.
I too am having this problem with the 3660.. I purchased a Blue Tooth Dongle, installed the software and it connects just fine, I can transfer files to my phone and everything.. But the PC Suite wont connect at all.
Whats that All About??
The problem is not on the phone or PC suite. The problem is about the transfer speed. When installing, the default transfer is set to 1200000..... (any way too much for the phone's IR). So i enterd the properties of my computer's device and i canged this speed at 57000 or so (I'm not in front of my computer at this time so i cannot give the exact values). Any way, I slowed down the transfer rate so, now the problem is gone.
