Update calender...
1 replies · 2,183 views · Started 17 August 2004
I have a nokia 3650, and im using the calendar-app for my everyday stuff. A friend of mine got himself af newer nokia (cant remember which model), and I noticed, that the calender app in his newer phone had a couple of new added features. (for example, you scroll over a date in month-view, and the specific tasks of that day is shown in the top of the screen - which is not the case in my version).
So, i figured, he could bluetooth me his calender.app file, and I would try to run the calender app from the new file on my phone - didnt work - typical.
Any ideas on how to update the calender app to a newer version? I was thinking, is the update maybe part of a newer firmware - cuz im using v.2.50, but havent bothered to update it yet.
To get that, you have to update to a phone with a newer release of Series 60. If you're in the U.S., consider the 6620, and if you're elsewhere, the 7610.
You can't update the calendar app functionality otherwise (no new features in new firmware releases, just fixes for known issues in earlier versions).
