hi all, plz help! when listen to my ringtones/alarm my volume is reasonable? but even though my volume is set at max, when i choose a ringtone it is very quiet? my alarm is even quieter? can hardly hear it, any suggestions welcome, thanx in advance. 😡
nokia 6600 volume prob?
i must be the only 1 with this prob? 82 hits no replies, help plzzzzzzzzzzzz... :con?
125 hits no replies? hmmmm!!!!!! nokia help 😡 didnt even reply?
I have got the same problem.
Ive just got my 6600 but its voice like nothing. cant hear anything although set to max. help ? advice ? comment ?
I had the same problem. I was talking to someone in the pub and they said they tested mobiles for a living. He said he tested the 6600 and found the same problem. His solution was to go into Real player and set the volume to max. He said that its a bug that causes the Real player volume to be the default for the phone's maximum volume.
I did as he said and it worked. Though its still not as loud as I would like.
Hope this helps.
Try Smart Profiles for nokia 6600 😊
I had some problems with my 6600, including sound problems, (i.e: the nokia presentation when I turn on the phone). The problem was solved with the new firmware v 5.xx.x.
Try { } and good luck.
