How Do you reset your operator logo
3 replies · 2,199 views · Started 18 August 2004
hey guys i made the mistake of changing my op logo on my 6600, now its not a clear with text instead it has a white background, which is blocking my themes and looks crappy
anyone know how to set it back to the default??
thanks
Red
go to menu,tools,seting,phone,and reset the phone factory the code # is 12345
reset the phone to factory settings? what r u on?!
either as said previous....use FExplorer or get yourself the Operator Logomanager s60 app to change it.
But FExplorer will delete it back to cell provider text.
Dont reset your phone 🙄
