9210i Sync with Mac OS X
2 replies · 6,336 views · Started 19 August 2004
:icon4: I have Nokia 9210i communicator, I would like to synchronize data (contacts, calendar, files) with Apple Power Book http://www.apple.com/powerbook/index12.html). kindly let me know the process for the same or any availability of third party software for the above mentioned product.
You need virtual PC 6 or 7, and windows 2000 (not xp, too problematic), and a usb to serial cable (connectix, or another brand, just make sure it is compatible with the rs232 standard). In virtual PC, you must activate the usb cable, and it should work fine with pc suite. Make sure the transfer speed is 115, and that you are not stuck at 9200.
It works, even if nokia helpline swears no 9210 can have a romance with a macintosh. But Good luck, it is capricious.
andymhaps wrote::icon4: I have Nokia 9210i communicator, I would like to synchronize data (contacts, calendar, files) with Apple Power Book http://www.apple.com/powerbook/index12.html). kindly let me know the process for the same or any availability of third party software for the above mentioned product.
Just wanted to ask if you could connect your Nokia 9210i communicator with Mac OS X and what exactly did you do. Also if you can mention your exact requirement it would be a great help.
regards,
Amit
