Im new one so i really need your help... I use Nokia theme studio and 6600 Theme Editor but im so headache about them cuz i don't know how to edit one existing theme...
When using 6600 Theme Editor, I can't edit the theme because the file extension is not *.mbm !! I chose UnSis soft to extract SIS file but get error "Error loading theme" when loading.... What does it mean??? And how to solve it...??? Plz show me one software to extract SIS files to MBM files (which can be edited by 6600 Theme Editor, but not "Unsis" cause i used it, and it doesn't work to this Editor) Itz really important to me .. I!!
The second problem about Nokia Theme Studio, i want to change the application background in "Crystallized" theme (cuz its whole white), whatever i tried, i can't do this...
So can you all plz help me to fix 2 problems... I upload Crystallized theme and the background application that I need you to replace... If you can make it, plz guide me how to do then I won't disturb you next time....
Sorry about my english (so bad, hope you understand what i mean!!
Thx you anyways
0010.sis (137 KB)
hi
i have the same problem ( error loading theme ) . can anyone tell us how 2 solve this plz?
thanx is adavnced
You're making something wrong, obviously.
I had the same problem when extracting the .mbm from .sis files with Total Commander. Bad proggy. Use UnmakeSis. A quick google around will get you what you need 😉
Then, just get the file bmconv.exe and put it on your MbmWizard (which you will have to use) and manually extract the resources you want to use 😉
You can't edit the .mbm with the Editor, I speak for me, 'cause I always do things this way, and it's the only one that works for me.
On a sidenote, do you know how to change the profile color? (on the main screen, the thing that shows "silence" etc?)
Hope I helped 😉
Arlanthir wrote:You're making something wrong, obviously.I had the same problem when extracting the .mbm from .sis files with Total Commander. Bad proggy. Use UnmakeSis. A quick google around will get you what you need 😉
Hope I helped 😉
I am new...I have a question because I have the same problem with theme editor!
After I have downloaded UnmakeSis, where can I find the file bmconv.exe?..and what Have I to do with Mbm Wizard?
Search the forum for bmconv.exe ive posted it a couple of times.
The instructions for mbmwhizard are also on the forum somewhere.
You shouldnt really be using parts from other themes as many are copyrighted material.
Mods : How is AAS on this topic?
