Hi all i have d/loaded a film clip, it is only 7.2mb i have it on my 64mb mmc but when i try to open with realplayer i get a message "Video is to large" am i doing something wrong or what is the problem.
Thanks.
Realplayer prob
Is it a Real Video 7, 8, 9 or 10 format video file? RealPlayer on the phone supports only Real 7 or 8 formats.
Has it been sized for the correct frame resolution for the phone?
Hmm now your asking something lol, i natually asumed because it is an rm file it would be ok, obviously not.
How can i find our matey.
Thanks.
Perhaps opening it in RealPlayer on the PC will say (file properties or something)?
It plays ok in realplayer on pc, this is info i get whilst playing.
shrek2_tsr_rm_500.rm
Length 2:03
Format RealVideo
Quality 500Kbps
Audio Channels 2
Rights Summary There are no rights or restrictions associated with this clip
Allow playback on PC No (play to authorize)
Content viewable until Unlimited
Copyright TM & � 2003 DreamWorks SKG
Composer -
Producer -
Publisher -
Label -
Distributors -
Studio -
danez wrote:It plays ok in realplayer on pc, this is info i get whilst playing.shrek2_tsr_rm_500.rm
Length 2:03
Format RealVideo
Quality 500Kbps
Audio Channels 2
Composer -
Producer -
Publisher -
Label -
Distributors -
Studio -
You are using file with too high bitrate for Nokia...If you have Nokia 3650 max. bitrate for a video file is 80Kbps ... So make sure it is,and if size of the video files goes over 176x144px that also can cause problems with playback...You can try to re-encode file,which takes loads of time or not use it....You decide...If you don't know how to re-encode just post it down and I'll try to help...
