Hi all,
I did a factory reset yesterday and now when ever someone leaves a voicemail thie icon doesn't appear..worked fine before the reset...any ideas?
thanks in advance
KP
Voicemail Icon P800
You may wanna do a full restore from your PC suite's Phone backup....
karmapolice wrote:Hi all,
thanks in advance
KP
Edgedale wrote:You may wanna do a full restore from your PC suite's Phone backup....
Just tried that...still no icon...any other ideas?
thanks
KP
If a full restore from your BACKUPs, then I may suggest you bring the phone to your nearest SE centre for a repair.... sorry dude. :frown:
You could always try a firmware fix on the SE update site?
Bassey wrote:You could always try a firmware fix on the SE update site?
Firmware fix ? Do you mean updating the firmware from a SE service center ?
I had a look at the SE website and found nothing about updating the firmware.
I think ill call orange and get them to de-activate and then re-activate the answer phone..maybe that will work.
KP
Definitely worth a try.
The SE Firmware update service is available here http://www.sonyericsson.com/spg.jsp?cc=gb&lc=en&ver=4000&template=ps1_1_5_6&zone=ps&lm=ps1_1&pid=10101
It is supposed to allow you to just re-flash the firmware you already have. That way, if there is a problem with the firmware, this should fix it.
I think Bassey is confused with the P900. You can update the P900 yourself, but with the P800 you can't...
Delta737 wrote:I think Bassey is confused with the P900. You can update the P900 yourself, but with the P800 you can't...
Yeah can't do it on the p800.
Is there any voicemail software available instead of having to use the network voicemail.
I remember some software on the Nokia phones that did this and just saved the voicemail to the phone?
KP
Nope unfortunately not! I wish there was such piece of software too, but unfortunately not 😞
