dim keypad
3 replies · 2,003 views · Started 20 August 2004
Just a quick question , ive noticed that when the keypad light is on the red end key isnt as bright as all the others . The c button underneath it is ok its just the red one .Are your phones like this aswell ?
thanks
gadget
gadget wrote:any chance of someone just pressing a key and letting me know ?
Mines the same mate.
thanks mate , cant believe my post was veiwed 25 times and you were the only one that had a 6600 to hand , once again thanks .
gadget
