Greetings all.
My used N-gage has a slight scratch on the front lens, over the LCD screen. I thought maybe some "iCleaner" (a compound used to remove scratches from iPods) might do the trick, but if anything... I've simply added little scratches around the screen. 😞
So I'd like to replace my "faceplate" with a new one, but I don't imagine Nokia sells them. Seems like it's easy to remove and replace, so I assume I can handle it. Has anyone bought the ones you find on Ebay and elsewhere? Are they any good? They are fairly inexpensive if they work ok.
Any info on legit replacement faceplates, or where you got one you like is appreciated.
merkman wrote:Greetings all.My used N-gage has a slight scratch on the front lens, over the LCD screen. I thought maybe some "iCleaner" (a compound used to remove scratches from iPods) might do the trick, but if anything... I've simply added little scratches around the screen. 😞
I bought a black one from ebay. The fit wasn't as snug and the black started to wear off after about 3 months. At least it was cheap!!
I just recieved my new faceplate from ebay today. Fits great and looks great! I got it for the QD, pearl. You should check out ebay.
NokiaOK has great N-Gage faceplates. u can search the phone sellers in ur country or on ebay. i have one and it looks great and it is a good quality product
drager wrote:NokiaOK has great N-Gage faceplates. u can search the phone sellers in ur country or on ebay. i have one and it looks great and it is a good quality product
My experience with Nokia OK covers is very different: http://www.allaboutsymbian.com/forum//forum/thread/26235/
Raven wrote:My experience with Nokia OK covers is very different: http://www.allaboutsymbian.com/forum//forum/thread/26235/
hmmm, Raven, my NokiaOK is really OK now. and now i'm holding and looking at it. maybe it is luck matter because mine fit directly and perfectly.
