Help!!!
2 replies · 956 views · Started 22 August 2004
im using a 3660...i cant turn on my fone...everytime i try it will request my password and then it will fade away and restart itself...after a few restarts the fone turns itself off...i tried removing both the sim card and the memory card but it wont work either...anybody got a solution???
Read this. I'm afraid the chances are you have the same problem as this guy, in which case, try the booting into safe mode first (rarely gives any result but is worth a try) or failing that, take your phone to a Nokia store and have the firmware flashed.
