MMC cards...
7 replies · 3,847 views · Started 22 August 2004
ok so i want to ge to get a mmc card but i would like to know some things first. First how does the data(music and games ext..) get into the card?? is there a adapter i put the mmc in and then plug the adapter into the usb or firwire??
i just need to know how it works before i but one..thanks
You can transfer music tracks using Bluetooth. If you use PC Suite, you can put them on the memory card directly. If you just use Bluetooth's file transfer, they end up in the Inbox on the phone first.
With the N-Gage "classic" you can also just connect the USB cable that comes with the phone and transfer the tracks directly to the memory card.
Or you can get a PC-based memory card reader and use it and after you've put whatever you want on it and then put the card back in the phone.
You can use the bluetooth or indeed a card reader ... you'll need a card reader if you want to transfer a lot of mp3's ...
how do i transfer games on my internal memory to the memory card?...using fexplorer?..
i tried doing copy paste but it wont work..
i wanna transfer ultra mp3,rally,prince of persia to my memory card from my internal memory...
sorry its kind ov a beginer wuestion am new to memory cards
You can do it with FExplorer, but you have to copy the files one-by-one & create the directories (or folders, if you prefer to call them that) separately (before you start copying); FExplorer cannot copy whole directory trees & multiple files.
shiv wrote:how do i transfer games on my internal memory to the memory card?...using fexplorer?..
deinstall them and then reinstall them, normally you won't lose any savegames.
i try transfering a mp3 file using card reader from PC then i slot it back to my phone then i open the ultra mp3 player but nothing inside the player! help me!!!!
nester wrote:i try transfering a mp3 file using card reader from PC then i slot it back to my phone then i open the ultra mp3 player but nothing inside the player! help me!!!!
Try rescan file system option if u have not tried it.
