Message storage on 6600
6 replies · 2,333 views · Started 23 August 2004
Is there a maximum limit to storing messages on the 6600, even though the memory is set to the MMC, after a certain amount of messages I get a msg saying that inbox is full, delete some msgs ?????
Also can msgs be saved to the pc using a usb and can any files be transferred from the pc to the phone or is it limited to just pics and mp3's or sound clips or certain formats
craio wrote:Is there a maximum limit to storing messages on the 6600, even though the memory is set to the MMC, after a certain amount of messages I get a msg saying that inbox is full, delete some msgs ?????
sir i need that software of msn messanger for nokia 6600 please send me that software at my id [email][email protected][/email] please i will be waiting for your replay
I believe it has a limit of 200 text messages unless you start moving them to your own folders.
Hi, I've already got more than 500 msgs in the inbox and more thant 750 in the sent box simultaneosly..
I don't know the inbox limitation, but sent can be configured in Messages > Settings > Other > No. of saved msgs.
The messaging becomes slow when you have lots of msgs stored...
It is very very slow to delete around 300 msgs...
Once a month I use an app called MessageStorer to save my msgs in plaintext ..
To transfer a msg to your phone, you just create a .txt in your computer, transfer to the phone... In the phone it will open using notes, so you copy and paste to the message you want to send...
Hope it helps...
