Is it possible to answer a call in loudspeaker mode with 1 keystroke; or must you answer the call, then switch to loudspeaker?
thanks again
Loudspeaker
I've not tried this, but thinking about it, couldn't you set the phone to "Any Key Answer" to answer a call using any key (excluding the disconnect) and then try using the "Speakerphone" button to answer the phone?
Hmm, at all I would like to set loudspeaker as default so I dont have to press the key each time, and to turn it off its enough to hold the phone to the ear ... but this seems not to be possible ... perhaps someone can write a hack 😊 ??
