i got a big problem.. i can't get the n-gage writing.. anywhere.. it only writes numbers.. in sms or other places.. problably was some erased file.. someone to help me?!
no letters
Most likely the reason is that you installed WildSkinz from WildPalm. It only works on the 7650 (if at all). If you still have it, use its feature to disable it, restart the phone, and then uninstall it. If you already uninstalled it, reinstall it and then disable it, reboot and uninstall.
