Remove software from phone
5 replies · 2,460 views · Started 24 August 2004
Mine are CDA162003/8, currently original software there is a demo inside. how to remove it and i cannot remove it, nothing show in uninstall icon.
Any idea to remove some download software from MS DUO and phone itself as I found that some of it fail to uninstall.
try regular uninstall from the application page.. if this odesn't work, then you can go through a manual uninstall, but won'r recommend this if you are not famillier with symbian file system!
mine is nokia 3660. I installed a software in my phone, ultra mp3. And I would like to uninstall it. any idea how to uninstall it?
