I ve had 7610 for several weeks but a few days ago it wouldnt let me make outgoing calls. Call disconnected comes up on the screen after a few secs. There is a 2 below the battery level, have I activited something by mistake?
Thanks :icon4:
Thanks :icon4:
The 2 isn't something to do with a second line is it and somehow you cant use the first line? Just a shot in the dark.
have you solved this problem yet as my 7610 is doing the same.
i had the same problem and it is to do with line two being activated
to turn line 2 off press and hold # (not *as it says in the book)
it then asks if you want to change lines just click yes and your all sorted 😃
UNBELIVABLE!! thought there was slim to no chance of finding a fix to this from a google search ------ WELL CHUFFED!!! cheers Misfit!!! 😊)
tucco wrote:I ve had 7610 for several weeks but a few days ago it wouldnt let me make outgoing calls. Call disconnected comes up on the screen after a few secs. There is a 2 below the battery level, have I activited something by mistake?Thanks :icon4:
its not working on my fone and it pissing me off HELP
