mmc reader trouble
1 replies · 6,249 views · Started 24 August 2004
Please Help! I just got a 256mmc from carphone wherehouse with a free Intgral mmc/sd usb reader. The card was preformated and worked in both the reader and the phone, but after using in the phone the reader can no longer read the card. What has my sx1 done to the card (it still works fine in the phone) to make it unreadable in the reader? Can it be fixed? I am using Windows XP so no drivers were needed fot the reader. Integrals web site (www.integralmemory.com) is no use at all. I am also guessing that CPWH will tell me to bog off as the reader was free.
Has anyone had a similar problem?
Thanks,
Bawbag
bawbag wrote:Please Help! I just got a 256mmc from carphone wherehouse with a free Intgral mmc/sd usb reader. The card was preformated and worked in both the reader and the phone, but after using in the phone the reader can no longer read the card. What has my sx1 done to the card (it still works fine in the phone) to make it unreadable in the reader? Can it be fixed? I am using Windows XP so no drivers were needed fot the reader. Integrals web site (www.integralmemory.com) is no use at all. I am also guessing that CPWH will tell me to bog off as the reader was free.
Thanks,
Bawbag
try to use mmc medic or similar app to restore the filesystem to fat16, which should be readable by both phone and reader...
