Infrared Connection
4 replies · 1,932 views · Started 30 September 2002
I want to get infrared connection and the only product I can find on the market is the ma620 but the home page for the product does not confirm compatibilty with the 7650? Does it work and how do u set it up to work with it? Thanks.
Why do people still go with IR! Bluetooth is the latest thing around!
Anyways, from my experience you can't really be sure that it will work with you PC Suite! It depends on the OS you have, on the hardware configuration of yourPC, what day of the year it is etc. Its totally random! Many people will say that it will work, but becasue they have no problem with the device thay don't search forums to see how many people has problems with that same device! So good luck to you!
I still advise you to go with Bluetooth thought!
I couldnt agree more now!! I though blue tooth was really expensive, but I se on ebay that I can get a usb connector for �25+. I thought it was nearer �100.00!!! I will have to send the ir back and get my money back I think! Thanks for your help. Ian
I have MA620 and it works fine !
cannot use the MA data suite but PC suite from nokia is OK with it ! ( from time to time ;0)
Thanks Mike, however I have managed to flog my ma620 to a guy at work and am awaiting delivery of Bluetooth!! 😃
