New: PowerNotes from Symbianware
0 replies · 1,940 views · Started 24 August 2004
Symbianware have released PowerNotes a program aimed at helping you take notes in the most effecient way at any time to help remind you of an event or an idea. PowerNotes allows you to take Notes in a Voice (recorded) or Text format. You can set reminders and view notes by date, category and more. Worth checking out if you reguarly use your phone to take notes and reminders.
User posted image User posted image User posted image
Symbianware's description:
If you appreciate your time and don't want to spend it on typing with the help of T9 input... If you need an application that will remind you about important events or ideas you need to implement at a certain time... Then you should definitely try PowerNotes, which greatly combines the functions of voice notes and reminders and also has handy views for viewing events sorted by months, days, categories and a lot more.
How does it work:
PowerNotes works with 2 types of records: Voice reminders and Text reminders.
To create a new reminder you should select a corresponding command from Options - New.
New reminders can also be created with the help of Hot key, to define a hot key open dialog Settings(Options - Misc - Settings) and define hot keys and actions.
If you want PowerNotes to handle hot keys you should turn on Reminder state option.
