6600 lock code and format
12 replies · 69,570 views · Started 24 August 2004
could anyone tell me if the format ( green * 3) code is also suppose to reset the lock code?
reason i ask is i have just bought a phone 2nd hand, and the previous owner can not remember the code. - so have done the format, but the code has not returned to 12345.
Is taking it to a nokia service centre the only way to reset the lock code?
cheers
Drew
Taking it to a Nokia service center (or reflashing the phone, to be more exact) is the only way I know to reset the lock code.
So, if the phone is locked, you can remove the battery, format it and still have a working phone??
Doesn't it asks for the code before formatting...?
With auto-lock set before formatting..
Doesn't it asks for the code the next boot after formatting?
I have used the following master reset code to initialize my phone when a menu item was missing. Backup anything important first as all phone numbers/software etc will be lost. Use it at your own risk - I offer it without guarantee but it worked for me.
enter: *#7370#
then press call.
If you do use it, please post the outcome to let others know if you were successful.
buzzlightswitch wrote:I have used the following master reset code to initialize my phone when a menu item was missing. Backup anything important first as all phone numbers/software etc will be lost. Use it at your own risk - I offer it without guarantee but it worked for me.
enter: *#7370#
then press call.
i dont want to reset it.. just want to get in and read my messages
Dear your code is working on my NOKIA 7610 but I want to format completly
please give me that codes
I think these codes are (*) (#) (send) (power) when mobile is power off.
but these buttons are not working when I press these buttons mobile gone to power on....
please confirm how should I press them?
Thanks your new friend Khalil
honey_c1237 wrote:can u plz give me the code for fileman
Use FExplorer instead, theres no need for a code.
hi
im mourad from morocco i m here to help any one to find (lock code) and to solve other problems.
i can find all nokia lock codes. just send me your imei to my email
( gentelmanmd[à]hotmail[dot]com ) i will send you your master code immédiatly
if your have other problems send me an email . i will help you if i can.
if you know any one have the same problem or other problem tell him to send me an email.
sorry for my bad english
good luck freinds
